I tried to fix my 6x6 fence panels to a 3ft high wall. Used 3 wall plugs and long screws at each side, but they have come loose from the wall at one side of one panel. To be honest, I'm not surprised. We found decent bricks to fix to, but it seems the plugs we used werent good enough.
Would I be better off with sleeve anchors? I'm just worried it will split the bricks in two! The wall is 100 yrs old and riddled with weeds / ivy / climbers on the other side.
I cant get posts into the ground here, as it is a concrete base adjoining the wall. The wall is next door's responsibility, but I wont hold my breath - its a rented house next door.
If money was no object I'd rebuild the wall. But I'm after a cheap solution!
The wall actually leans slightly, and this is amplified at the top of the panels when fixed - they have to twist slightly, putting pressure on the fixings. I'm not sure whether to wait until I get my decking and fasten posts to the joists for the fence. I wanted a quick cheap solution. Any ideas?
