Hello,
I need to fix a wooden gate post to the side wall of the house to hang a gate. The gate is 6' x 3' 6" wide, the post is 1.8 meters x 3" square and the wall is brick.
I've bought these frame fixings (76148) from Tool Station:
http://www.toolstation.com/shop/Scr...s/Frame+Fixing+10mm+x+135mm/d90/sd1950/p76148
The fixings are 10mm x 135 mm which are suitable for a maximum fixture thickness of 90 mm.
I was going to put two fixings at the top of the post where the maximum leaverage will be, one in the middle and one at the bottom.
The bottom of the post will also rest on the path.
Is this likely to be strong enough or is there something else I should be looking at?
Thank you
Thank you
