Fixing gate post
6 Mar 2008
Cumbria
Hi
I am going to fixing a new gate (when it arrives). The gate will be approx 7ft wide by 6ft high and made of timber 3x2 frame and 90mm x 13mm t&g (to give an idea of weight).
I have purchased a 100 x 75mm treated post and am intending to fix it to the side of my house (brick). I am going to mount the post so the 75mm is between wall and gate.
I was thinking of using 3 or 4 M12 recessed sleeve anchors to mount to the wall.
Question is....would this be suitable to support the weight of the gate?
Is there a better way of doing it (except for resin systems...which sounds a bit too much hassle for a novice DIYer like me)?
Any help/advice would be much appreciated.
Regards
Patrick
i would definatley suggest resin anchors (chemfix or the likes that fit into a mastic gun) and suitable studs as these will not crack the brickwork like expanding anchors.
Simple enough to use.
If you drill say a 12mm hole through the post, then recess it with a 25mm hole, then 10mm chemfixed in (12mm masonry bit).
cut the stud the same as the face of the most, and the nut and washer will sit in your 25mm recessed hole.
