Fixing insulated plasterboard to solid wall
9 Aug 2021
Hi
I wish to fix some insulated plasterboard to a solid end wall. It is presently smooth and plastered. I want to tape and joint and so need the plasterboard to be flat.
Do I just use adhesive or are there fixings that will sink below the surface please?
they are only small and then only go into the inner leaf of a cavity and if its a solid wall then what 6 small points are possible cold brigdes, compared to the gain from the insulated PB thats going to be a minimum loss.
