I am in the process of installing a cat tunnel through a cavity wall.
Pictures here: //www.diynot.com/network/churchilldog/albums/3515
As you can see from the pictures the hole is slightly bigger than the lining, and there is one more lining piece to go in on the outside of the tunnel before the flap is installed.
In order to give the best seal, I propose to fill around the final liner piece with a low expansion foam. Once this has set, been cut to shape etc, will it be enough to fix the flap into this (and if so, how should I do this, screw directly or drill/ plug and screw) or should I come up with a different method, like securing some wood either side of the tunnel then securing into that?
I've already foamed the inner piece of the tunnel and think that this will work out well once it has cured, indeed the foam seems to be holding it without screws, but I would rather get a mechanical fixing it, especially on the outside of the property!
View media item 13765
