- Joined
- 2 Jan 2016
- Messages
- 9
- Reaction score
- 0
- Country
Hi all. Was hoping somebody could advise about low water pressure.
Our house is at the end of a run of 4 houses that was originally just one, and hence all share the same water main.
As a result, for example, if using the shower, and the 3 neighbours upstream run a tap each, then our shower becomes just a dribble at best.
I was told that a pump placed in line on the mains inlet pipe to the house would help pull the required water through the pipe and maintain pressure.
Is the true? And if so, what type/size of pump would be needed for 2 bathrooms and a downstairs toilet, plus kitchen sink, combi boiler and washing machine etc?
Also as noise would be an issue if a pump is heard kicking in every time the water is demanded, are there silent pump options available?
Many thanks for any help.
Paul
Paul
