Painting some woodwork at home and I've run into a couple of problems.
"Trying" to do things properly I sanded down the old paintwork and applied a coat of undercoat. So far so good.
When I was applying the first main coat of paint (Dulux Quick Dry Satinwood) I was finding that some areas were "dragging". It was like the paint was drying too quickly and going over the same area was moving small areas of dried paint around - not lumps, but like a layer of paint breaking up. I wasn't working THAT slowly that the paint should be drying completely. Trying to fix it was making things worse. In the end I needed to rub off the whole door frame before it dried and do it again.
I was dubious about a second coat but thought it was maybe a one-off. But NO.
It's not as bad this time but I've left it to dry this time as I didn't fancy doing it all AGAIN. I've now got a small area which I'd like to fix if I can. If it was behind the door I would leave it but it's right at eye level.
Would it be OK just to sand this bit down (it's about 1" x 3") and repaint it or would that look worse ? Also, I've now got some paint runs on the door - I didn't want to try to touch these while the paint was drying for the same reasons I've mentioned above. Would it look bad just sanding these parts down and repainting ? I think I'll get the same problems if I try another full coat.
Cheers
Cheers
