Fixing Pipes To Foam Insulation
11 Jun 2006
Cheshire
What is the best way to fix plastic JG pipes to foam insulation - both with and without pipe insulation?
I don't believe foam insulation is renown for its structural integrity, hanging stuff off it probably isn't going to work. Cutting a channel in the insulation and putting the pipes in it might, it would also solve the pipe insulation problem at the same time.
