fixing plasterboard to breeze blocks
29 Mar 2008
Could anyone help me as i have removed my tiles in bathroom.and i have wrecked the plasterboard.Now i have cleared out the old stuff,i want to fix a new sheet of board up on the breeze blocks,should i use adhesive,cement,screws,nails.not sure?
Standard plasterboard will disintegrate if damp gets under the tiles so on areas subject to continual wetting - shower area, next to the bath etc, it’s best to either use Aquapanel (my preference) or tank the area; at the very least you should use moisture resistant plasterboard.
Richard is right if you want to do the job properly your best off getting Aquapanel its moisture resistant and will do the job dapper.
my neighbour said it's good if i pva the wall before tiling.but this aqua board sounds like the stuff i need.thanks again
Won't really help keep moisture out; in fact it's not a good idea as I believe it actually weakens the tile adhesive bond!
