Fixing plasterboards brackets to floor joists
6 Feb 2013
Hi
Help can you please advise I have Concrete Floor Beam 3m in length for a floor above a cellar,
now I would like to attach plaster board to act as a ceiling but do not want (obviously) to drill the floor beams ?
can you advise of a bracket that can clamp to the beam so that we could attach the brackets to for the plaster board to attach to ? or any other method ?
many thanks
You new plasterboard, is it going to be lower then the beam or as flat to it as can make it? I would rely on fixing galvanised strips to battens, then "glueing" the metal surfaces to the the concrete with epoxy resin or putty and use clamps temporarily until the epoxy goes off. The concrete surface must be dry and not dusty.
Frank
