Hope you can help. Despite reading other posts on fixing angle bead nobody seems to have addressed how it is positioned to get a 3mm skim.
I have a newly plasterboard boxed in vertical soil pipe. Using the black plasterboard screws won't be very successful I would think because right on the corner the screws won't reach the batten wood inside, so it ends up spinning in plasterboard. I favour Gripfill, is that ok?
The bigger question is if I push it firmly over the external corner, the bead will be less than 3mm from the surface and the mesh part of the bead will be very close to the plaster skim surface.
So, do I squeeze the angle bead to be less than 90deg before fitting which will push the bead proud, so that I will get a 3mm skim? As stated, the fear is that if I don't do that the skim when level with the bead will be very thin and expose the mesh part, or the plaster won't want to adhere.
Your comments please.
Many thanks
Many thanks
