I\\\'ve got a dry-lined wall with thermalite blocks inside - not very good at taking plugs. Whats the best way of fixing the brackets securely, given that the rad/bracket will be hanging at least an inch from the block cos of the drylining. There\\\'s a cavity between the plasterboard and the wall.
I\\\'m currently planning to use the teachnique I used for the sinks - fix a threaded stud into the block using expoxy resin. But if anyone\\\'s got a better idea ...
