Hi, this is my first post here. Please be gentle
I have a 1970's double garage built with bolted together concrete panels (Marley type ?). It has a Steel girder running down the centre of the garage , and concrete beams fixed across the garage to which a concrete corrugated roof is fixed with "J bolts".
The roof is past it , is flaking and has cracks so it is leaking in several places. I assume the roof has asbestos content so am trying to find a way to fix the roof without major expense or hassle.
I was thinking about fixing wooden straps onto the existing roof, then nailing on new bitumen roofing panels. The problem with that approach is the existing "J bolts" aren't long enough to fix wood straps ! (the "J bolts" hook under the concrete beams and the roof is bolted down).
I thought I'd be able to buy longer "J bolts" but I can't find any to supply them. I thought about making some with threaded rods, but there must be a better way
Am I making my life difficult ?. Any better ideas (which won't cost a fortune disposing of old "asbestos" roofing ?
