I hope I'm posting this in the right section.
I have a large supporting oak beam in a 1840s cottage. It runs across the living room ceiling and into each wall. The end that enters the left hand wall which it the end wall of the house is partly soft and rotten in a small area. I have no idea what its like in the wall I can only guess it is bad. The rest of the beam is solid and I can only assume that because the wall had damp issues (thanks mainly to 1980s decoration using modern materials (not mine as I've only owned it a couple of years).
Removing and replacing the whole beam is going to be extremely messy and very impractical as it runs through the right hand wall and into neighbour's property. Has anyone had to repair this sort of situation? Any ideas?
I thought of cutting out a section of wood bolting in a piece of steel and covering it with the bit I cut out, but I'd like to get as many ideas as possible.
Many thanks
Gavin
Many thanks
Gavin
