Fixing shower enclosure onto plasterboard
27 Oct 2006
Devon
Hi, I am about to fit a shower enclosure onto tiles/plasterboard. The fixings supplied are wallplugs for solid walls so are no use. Is there a similar type of wall plug specically for plasterboard or do I need to use one of the fixings which spread out at the back of the plasterboard.
Gordon
the standard wall plugs are useally ok if the walls tiled aswell.
or you can use the plasterboard ones that spread out.
but i've never had an issue with standard plugs.
