Fixing Sleepers
Thanks very much.
As my drill bit is about 210mm long I suppose I should drill through the first sleeper, the drill bit will then mark where I'm supposed to drill for the 2nd sleeper?
I suppose I should also use the odd stake along the back also?
Is that right?
Thanks for your reply.
Raised bed. So I will go for the posts and screw into them from the front of the sleeper..
The sleepers are 2400 long, so I suppose a post every 2400 and put the sleepers down like you would bricks (overlapping)?
I agree that it might be best to use short vertical posts fitted behind the sleepers to support them, but if these posts are wooden they will need to be to be substantial and soaked in preservative. You might be better off using heavyweight angle iron and concreting this into the ground about 3-500mm. Drill holes in the iron prior to concreting and then bolt through to your sleepers using M10 roofing bolts or similar. Don't underestimate the pressure of wet soil in the winter trying to push your sleepers out of line!
Best to use two posts per sleeper, maybe 400mm in from each end. Don't put the posts right at the ends of the sleepers as the wood may be soft there and the bolts might pull out
On the plus side, if the soil where you are placing your sleepers is well compacted first then I don't think there'll be any need for a concrete foundation under them.
Hope this helps.
Yep that's right but you want to put a post at either end and one in the middle too because when you stagger the joints like brick bond the end of the next course will be mid span on the one below.
You can use off cuts of sleeper instead of posts if you like. for 400mm high you don't need to go crazy, a foot in the ground will be plenty.
