I have plywood panelling on the side of my stair and want to install a flush socket on it. There is moderately good access to the back side of the panel from the solum under the stair. I have read that I should not use a metal box for fire safety reasons but instead should use a drylining box. I haven't come across these before but they seem to have lugs that extend out from the side of the box and tighten against the back of the plasterboard (in the normal case of use with plasterboard).
The plywood appears to be about 8 or 9 mm thick but I can't tell for sure until I drill into it, which I don't want to do until I know I'm going ahead with this!
My questions are:
Would a drylining box be safe and suitable for mounting the socket on the plywood? Btw I live in Scotland (mention that in case the regs are different in this respect).
Would the lugs grip the plywood adequately or do they require to dig in as they might into plasterboard?
Do drylining boxes have knock-outs for the cables just like metal boxes?
Thanks.
My questions are:
Thanks.
