- Joined
- 23 Apr 2021
- Messages
- 6
- Reaction score
- 0
- Country
Hi all,
I have a DIY conundrum which I am struggling to find an adequate solution for.
I have two bits of 2m long 1" x 3" wood. One of these has already been firmly attached to an outside wall on my house using 2", size 6, screw right through the wood and into the, rawl plugged, brick work [ and is not going anywhere anytime soon
]. The other piece needs to be attached to the first so that (a) it can swing out, from one end, so that it becomes perpendicular to the wall and (b) can, also, just sit in front of the other piece. I also need something that will keep the two pieces together in scenario (b) so that hinge just doesn't open out slightly.
I figured this would just require a hinge, at one end, and a supporting 'leg' at the other end and this was all working well for about a day but then the hinge just gave way bringing the 'outer' piece of wood down.
I am presuming that my hinge and leg just weren't up to the task but am struggling in terms of what I should be looking for. The first 'leg' was 34mm x 34mm - which I thought would be adequate - but maybe a more solid 2" x 2" would be better. ? It is mainly the hinge that I am really struggling with - or whether a hinge is the best option in the first place ?
Any expert [ or just more expert than me
] DIY-ers got any ideas ?
