I have a 1960's house built with cement pantiles with roofing felt underneath.
We have some leaks in the loft, primarily where one ridge runs at right angles into the main roof, a few tiles below the main ridge. The water seems to be getting in where the valleys run down.
I can see some ridge tiles above need repointing, whereas I can't see anything amiss with the valleys. Am I right in saying that I need to totally remove the ridge tiles and lay fresh mortar or can I get away with using some kind of sealant or scraping away an inch or so deep and repointing like you would with brickwork?
Many thanks
JD
Many thanks
JD
