I’m having a bit of a panic about how I’m going to fix a wall-mounted sink and cabinet to the wall. The walls have been dot and dabbed and will be tiled.
Where I’ve fixed into the wall so far, I’ve used these http://products.dewalt.co.uk/fastenings/productlist/hierarchy/2872/ and it’s often taken two or three goes to get the fixing tight due (I think because I can’t see past the plaster) to the brick crumbling and not holding.
I can’t drill half a dozen holes through the tiling and hope that I get two level, plus because it’s dot and dab there’s the gap between the brick and front of the tile where the end holds the sink up which will be around 30mm and cantilevered and I’m not convinced it’ll hold.
What is the done thing here? Surely this must be a reasonably common occurrence...
