I've had a Plasterer use dot & dab to true up some walls in our bathroom after removing all the old soft plaster.
I now want to fix some radiators and bathroom furniture to the walls and am wondering what the best fixing solution will be.
Having drilled an exploratory hole, the cavity between plasterboard and original brickwork looks like about 8 to 10mm max. in some places it's probably touching as the walls were very rough. So I don't think I can use traditional cavity type fixings.
My thoughts are to use longer screws and push the wall plugs through the plasterboard and into the brickwork behind.
Is this sensible or will the fitting when tightened, start to pull the plasterboard toward the brickwork and crack.
Or is there a super-duper fixing that I've not come across that does the job perfectly & doesn't cost an arm & a leg!!
Richard
Richard
