Below is my toilet cistern - big dome type rubber washer over the cistern outlet. Do I need to use silicone or anything when fitting the cistern to the pan? I presume the two bolts are to fix the cistern to the pan and not to fix the cistern to the wall (with wingnuts)? Is it worth putting a bit of silicone on the two washers for the fixing bolts?
