You might want to use spring toggle fixings
Cheers. Was planning to use them but more concerned about the overall weight of tiles and a towel rail on D&D wall.
If it's dot and dabbed then you'll only have a minimum gap before you hit block/brick. Nice long drill and then use 100mm screws and fix it to the brick/block with raw plugs. Just don't over tighten the screws so it doesn't pull on the board too much.
dot and dab internal hollow walls
Why would anyone want to dot and dab partition walls? Surely it easier just to pull the old board off and fit new or just screw new on top?
Sorry never seen that, why would you ?I suppose it depends if it’s a brick wall, I’ve known people to dot and dab internal hollow walls
