Fixing TV mount to solid wall - which fixings?
15 May 2013
I've just bought one of these:
http://www.ebay.co.uk/itm/3D-LED-LC...Wall_Mounts_Brackets&hash=item3f18715c71[url]
Will the supplied wall plug and coach screw be OK to fix to a breeze block wall? Its for a monitor so only 5kg or so but as its a long bracket i'm guessing the fixings need to be pretty solid.
Its going in the garage so the other thought I had was to fix a piece of 2x4 to the wall with 4 or so 5x80mm screws and wall plugs with no more nails in the in the plugs.
Thought about resin and threaded rod but i might want to move it later and thats not really an option with resin!
Thanks in advance!
More than enough unless it's thermalite blockwork, which requires twisted wall plugs for better grip.
