fixing wall plate to clunch(chalk) wall
M
munchingB
any any any ideas? was hoping to not have to build a foundation against said clunch wall for fear of undermining it as it sits on a flint foundation itself.
im thinking the obvious thunderbolts or anchor bolts etc but don know which is worse-fixing into the lime mortar of into the chalk itself as both seem pretty lousy : /
also thinking to put 3 foundation blocks maybe a foot square and run a big wood beam across the lot, build a stud on top of that and then another substantial beam on top of that...?
its only for a conservatory/greenhouse but i seriously dont want to disturb the ground near the existing clunch wall.
cheers
Could you not sit a wallplate into the brick lean-to and fasten the other end to the brick corner. With, for instance, threaded bar in the mid-span fixed with resin..?
