Fixing wall plate
8 Oct 2011
Just a quick one.
I am fixing an 8"x2" wall plate to my wall for a mono pitch side extension.
I'm using 100mm thunder bolts and timber connectors (BC wants these). Fixed every 500mm off centres.
How important is it to make sure the bolts hit the bricks rather than mortar joints AND what would be the nearest I can fix them to edge of timber?
I'm trying to line up the joist and haven't got much to play with.
Cheers
i figure you intend to fix a lean-to roof rafter ledger to an abutting wall.
after fixing the ledger level with a bolt at each end, you can drill through the ledger into the brickwork with the ledger in place.
fix your bolts in each rafter bay @centres of 400mm.
fix into brick not beds or perps.
Thanks, I was going to stagger the bolts. In order for me to do this I would need to drill about 2" from the edge of the timber.
You also suggest 400mm centres for the rafters?
Thanks for the advice
staggering fixings is good practice but no need in a ledger thats not taking much downward pressure.
typical practice is to centre all timber framing centres eg. rafters & studs on 400mm.
Brilliant,
Really appreciate the advice.
Thanks again
You don't need to use such a massive piece of timber, 4x2 will do. But for wide timber sections staggered fixings will stop the timber trying to twist as it dries and acclimatises.
Fixings need to be into brick, and then into brick not the frogs.
As for using timber connectors that's just a WTF? moment.
I had 8x2 left over and would only go to waste otherwise. Might as well use it.
I'll stagger the bolts trying to get them into 2 different courses. I will check which way the frogs are as there is a section of wall exposed elsewhere.
BCO requested connectors, truss clips and 2 birsdmouth cuts. I don't mind as I'm not a chippy and it will be more solid and peace of mind for me.
With regards to the bolt placement, could I fix bolt within a couple of inches of timber edge? It would enable me to comfortably get the fixing into brick.
Cheers
Divide the depth into thirds, and that's your bolt lines
Your BCO is clueless. Truss clips have no lateral restraint (ie the rafter could slide forward). The rafters should have a seat cut and be spiked, that's it.
I can't think for the life of me what timber connectors would be for in this situation.
