Hi all,
Fairly new to all this so be gentle with me!
I've got hold of some nice old scaffolding boards which I'd like to use for shelving. I'm ok with sanding them down and all that, but a few things I'd like to double check on in terms of the fixings.
I'm going to use these Triade concealed shelf supports as I'm looking for a floating feel, and I like the fact that they're adjustable to get things nice and level.
http://www.hafele.co.uk/shop/images/External/pages/105-110.pdf
Two main questions I have
1. I don't have a workshop unfortunately, so my first question is whether I'n likely to be able to make the holes in the shelves straight and accurately enough without a drill press? I'm guessing if I'm even slightly off, it's not going to work. I have bought this drill guide from Axminster. http://www.axminster.co.uk/axminster-drill-guide but is it basically crazy to try to do this without a press? I can probably find one somewhere but it makes everything a much bigger hassle.
2. I just want to make sure I'm clear on the weighting - the shelves will be 2 meters long, and I'm thinking of using four supports - it gives figures in the pdf above for them being 700mm apart which I guess signifies 4 supports for 2m, and that at a shelf depth of 225, that this should give 140 kg/m which is easily enough to hold the shelves (which are about 10kg I think) plus even heavy books which I think even the heaviest I understand are about 150kg for 2 meters of length, so I'm guessing this makes them able to take almost twice as much weight as I need them to.
Would love to know if these figures look right, don't want them collapsing!
Should say it's a masonry wall, so I'm guessing that will easily take the weight if the fixings are hefty enough.
Have more questions but these are the key ones and would love to know in general whether I'm on the right lines here..
Louis
Louis
