I'm looking at fixing 50x50mm vertical battens at 400mm centres onto a party wall (for noise reduction), but I'm not sure which fixings I should use or the spacings between the fixings.
It's a 1930's semi, single brick party wall with sand/cement render and plaster (which is old), and given that I'll be hanging 2 layers of 15mm plasterboard I'll need to fix directly into the brickwork.
Should I use something like hammer fixings or frame fixings like the kind of fitting windows and doors?
Alternatively, if I built a seperate stud wall using 3x2 is it still possible to get a sturdy result if I fixed it to the adjacent walls, floorboard and ceiling with bracings/noggins or do I just need 1 run of noggins across the middle?
I know a totally seperate wall is the better option, just trying to minimise the space loss
