I live on a new-build development, 8 years old now. It's built using brick. and they also used the same (I think) bricks on walls surrounding gardens, yards, etc - low walls with small towers and railings in between.
Throughout the estate, there are lots of problems with the bricks flaking and falling apart on these small walls. Flat pieces about 5mm thick are regularly coming loose and in some cases, whole bricks or even courses of bricks are loose or falling off (mainly on the small towers which are basically 2bricks x 2. Also lots of white markings on the side of the walls (damp?)
At times you can walk down the street and see bits of brick all over the place.
I think the flaking is frost damage but really, should such newly build walls be falling apart? Is this a worry for the main house walls - does it indicate the bricks are bad or that the outside walls are uncapped in some way?
Also, how can one fix this? And since it's a street managed by a housing company is there a case to chase them about it... literally every house has this problem?
Thankyou... I can get photos if needed.
