Flashing Lights on WT540
12 Mar 2013
Hampshire
I have a Hotpoint Aquarius WT540 washing machine.
When I first power it on I get every light flashing but eventually (so far) all lights go out & I am able to set the program. Why do all lights flash please?
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
If every light flashes its the c17 cap on the pcb. Loads of threads on here about it.
I'm currently having the same issues described, with 4 lights flashing. I have removed the lid and can only see one PCB that doesn't have a legend/ident/top silk which I don't believe is the PCB with the C17 I've read in other posts, would somebody be able to tell me where the PCB is located as you are looking at the front of the washing machine?
