Flashing Strobe Light on Accenta G3
21 Mar 2018
The external strobe light on my alarm system has started flashing continuously even after I have reset the system, can anyone help?
Normally the bell box strobe will flash during alarm when it is sounding, after that it may flash until the system has been reset.
if it is flashing continuously and you have reset the system properly, there could be a fault with the panel, bellbox or cabling.
Which bell box do you have?
So it was ok until you reset the system, why did you have to reset the system?
I've come across this on ADE panels optima's/ accenta's/ logic 4
Sometimes the strobe output gets latched, only solution is to power down the panel
well off and on again if all else fails is always good back up?
never had it to be honest, thing is down powering the panel every now and agaon to stop it is going to be a ball ache,but would guess its not a regular thing.
