Hi all. I've had some radiator cabinets made to order but I'm struggling to find the fixings I need to fasten them to the walls. In the past when I've bought off the shelf cabinets, they have had a very specific type of fixings in the pack that I just can't seem to find anywhere. They have an L-shaped bracket that attaches to the top of the cabinet, with a sort of flat metal 'loop' that screws onto the wall with two screws (basically, almost a flat bar with just a tiny raised kink in the middle). The L-shaped bracket simply hooks over the loop to stop the relatively stable cabinet falling forward, but means its super easy to remove to alter the thermostat or bleed the rad. I've thought about other options but no matter what I try, this still seems to be the ideal solution. French cleats are no good as the rads are really close to the wall, and the cabinets very close to the rads, I've tried various cupboard catches and mag catches but they aren't strong enough and keep popping open, concealed mirror fixings are no good because we don't have two flat surfaces, and I can't just screw to the wall as we have thermostatic valves so need to be able to take them off easily to adjust the temp from time to time. These brackets obviously exist as i've seen them loads of times, but I just have no idea where to find them! The L'shaped bit is easily dealt with, but the loop seems like an impossible dream. Anyone got any idea where I could find something like that?
(Before anyone says to ask the cabinet maker, I can't as they messed up the cabinets a bit and I'm having a bit of a dispute with them about it so I don't think they would be very happy to help!)
