hi all does anyone no if acrypol + will seal capping felt as it says removing chippings on ther web site and i can,t without damaging the felt any help please .
yes it will, but you may have to do two coats. I used Liquid Rubber not agropol (having used another makers version, ity's very hard to use over a large area). Rubber is water based, easy to spread and 1100% flexible so will cover stones with no problems.
