Hello,
I am about to replace a felt flat roof that covers an old coal shed and outbuilding that is connected to the back wall of my house. My intention is to convert the rooms that currently have no heating to a study and small second bathroom.
As the building is single brick and has a concrete roof I am considering how I can effectively insulate the roof to prevent condensation (as it is currently a problem being a cold room). From the reseach I have done it appears te best way to do this would be to make the ceiling a warm roof which seems relativley straight forward, but I do have a problem.
One side of the Flat roof is shared with the same outbuilding that my neightbour has, with the only feature between the two flat areas being a small ridge under the felt that prevents the water from flowing between the roofs.
If I add insulation of about 100mm to the top of my roof it will raise the height above that of my neighbours roof and I am concerned about the knock on effect of this to the roof next door, therefore I was wondering how I should go about terminating the insulation where the roofs join to keep the water on my side fo the divide; for example should I terminate the insulation early so I can form a channel next to the rige between the two roofs therefore preventing water from flowing on to next door?
I apprecatie any comments about my approach and any advice with this as I cannot find any information online relating to this type of problem?
Thanks for your help in advance.
