We had roof works done in 2014, completed around september.
These were to the pitched front roof (new valley liner and complete strip off and put back
on all ridges and cement up valley and new flashing.
At this time we had no issue with flat roof and had not had since 2011 when we moved in.
May this year and flat roof over bathroom starts to leak.
The flat roof connects straight under the bottom of eaves of pitch roof.
(no gutter)
When they did the work mentioned above they used a few of the tiles from the back for the front job as must have broken a few and replaced with the reds shown in pic.
They are the same tiles, Redland 49, but are not identical.
Main difference being the interlocking grooves; old ones have a double groove and reds have just one groove.
Do you think the reds could be cause of new leak. They happen to be directly in line with where the leak is coming through in bathroom which is raising suspicion. Also this has happened quite soon after the other work completed. Flat roof covering is old but seems fine and they said at the time it doesn't need any attention.
We spent a considerable amount of money on the other work so are hoping this is something straightforward!
Thanks for your time.
Dan
(no gutter)
Dan
