Flat Roof Leaking
29 Dec 2008
Cardiff
My feltet flat roof is leaking in some areas where the felt has been set around corners and in other angles from new. The rest of the roof is ok. Is there some kind of compound/sealant I can use on these areas which are about four inches by twelve inches? The roof is about fourteen years old
just be careful youre not sealing in wet/moisture.i'd wanna check there is no rot in the leaking area's before just sealing over the top.
