I have a flat roof covered with mastic asphalt and I have a couple of leaks to fix. One is immediately obvious as I can see a couple of small cracks in the roof and these are right above the water damage in the house. The other is a bit more difficult - there are stairs going up to the roof which are joined to a chimney. The canopy of the stairs is also covered with mastic asphalt which has been angled up to the edge of the chimney where the 2 meet. (hope this makes sense!). The chimney is not used and is capped off and covered with cement, but I suspect the water is either coming through this (as it is uneven and covered in moss) or on the side of the chimney where it joins the asphalt. I tried waterseal, but dont think this stuff is much good.
My thought was to buy Acrypol+ and just coat the whole top of the chimney and down the side to meet up with the asphalt on the canopy. I'd also just smooth the acropol over the other crack in the roof.
I'm after a quick fix as I am selling up the house and I have had one guy out to quote who wants £500 to do the above mentioned work. This seemed expensive and thought I could probably do this myself?
What do you think? Any help much appreciated!
