The actual metal detail in this region, called pulsating, requires cautious execution, so the different areas of the roofing can proceed while leftover watertight. Joints covered with roof covering tar or even cement generally indicate bad craftsmanship and can not final long, because the cement rapidly becomes brittle as well as cracked.
