Hi all,
We have an outbuilding with a flat roof, the flat roof felt was replaced just over two years ago but before we moved in.
As you will see from the pictures, water pools on top of the flat roof and you can see that its physically sagging down in the middle. This is obviously a bit of a concern and so we got some quotes on to fix/replace.
We've got three types of option and quotes and I'd very enormously grateful if you you could give advice on your preferred options - i.e. what would you do if this was your roof!
1) Add a beam down the middle of the roof (width ways) to raise the middle, leaving the original joists and board in place and essentially building on top of it then re-felt. Quotes come in at approx. £2000-2200. 10 year guarantee.
2) Replace the joists and boards and re-felt the roof. Quotes come in at approx. £3500. 10 year guarantee.
3) Replace the joists and boards and put a PVC membrane advanced flat roof solution in place (company called High-Tech membrane roofing). Approx £9000. Guaranteed for life.
The actual felt looks fine, unfortunately the work underneath and to ensure that the roof drains appropriately was not good. To me option one makes sense and the guy who reviewed it and quoted the work is very well thought of, but I'm not sure if I just like it because it's cheaper!
So any thoughts much appreciated, thank you.
Darren
Darren
