please what is the general fall or formula of a felted roof on an extenstion
the roof i am working on is about 6 meters long
yes masona roof size.... 3m wide x 6 m long so the cutter is at the short endIs it 6m to the gutter?
cheersNormally minimum 1:40 for rainwater to drain off
tar cambridgeroofer...very useful informationThe correct minimum fall of a flat roof should be 1:60 by design to acheive 1:80 with deflection ie sagging over time but with flat roofs with a gutter and no internal outlets to worry about over whelming the greater the fall the better. 6m/60 = 100mm difference between top and bottom
