Flat roof to brick built shed
30 Nov 2011
Staffordshire
Hi just wondering when you make the change from nailing the felt down onto a shed roof to using torch on felt? Its an old concrete block built shed want the roof changing just as cheap as possible so can the roof be relined with plyboard then use shed felt nailed?
Most sheds have felt nailed on so don't see the problem.
Yes - You could also consider OSB 3 instead of ply
http://www.osb-info.org/rightgrade.html
