Hi - I probably already know the answer to this....but here goes.
I have a single garage with part pitched, part flat roof. The flat roof is leaking in the corners (not much surprise there) and I need to do something in the spring to fix it. The pitched part of the roof is fine, just a bit of pointing to be done around the ridge tiles.
What's the general life span for a flat roof? If I have the flat roof re-done, would I be throwing good money after bad? Are flat roofs any better than they were years ago? I think the roof on my garage is about 7 or 8 years old.
I'm going to have some quotes for a full pitch and also to just re-do the flat roof part.
Is it worth renewing a flat roof or in the long run should I just save up and go for a full pitched roof?
