I am considering some options around remodelling the back of my property to knock down an existing flat-roofed construction and replace it with a marginally larger one with large glass doors (roof size of ~5m by 2m or thereabouts), with probably a zinc roof. I will require a structural engineer to design some beams, but I'm exploring ideas so I know what I want to ask him and not waste his time.
I have seen a number of pictures of designs that look quite appealing to me, in that what they appear to have done is to make the area above the window look - from the outside - much thinner by putting the window in front of the roof joists.
That might not make total sense. A picture is worth a thousand words so:
I'm looking for drawings that will help me understand how it has been constructed. I'm assuming that it's a warm-roof type construction, and that the doors transfer the majority of the weight to the bottom. What I'm not sure about is the detail around the overhang that presumably the top track attaches to, and how that's connected to the front beam so that it's all strong enough. I don't know if the structural deck (e.g 19mm plywood sheet) is simply left proud of the front supporting I-beam and that is sufficient (and thus the outside 'lip' is the height of the plywood + insulation) ?
Is there a name for this that would help me target google searches?
