Flavel Finesse 100, fan oven working but other not
27 Oct 2008
Leicestershire
My two year old Flavel Finesse 100 Dual Fuel has decided to start playing up, the fan oven on the left still works but clock and other oven have stopped working, wondered if it was a loose connection or something any advice or tips greatfully received
I had exactly the same problem. Here's how I repaired it: remove the large back plate behind the oven that is faulty. Hidden within a red sleeve around the brown (or is dark grey?) cable is an in-line thermal fuse. I replaced this with one from Maplins and all was good.
Note. Sliding the red sleeve to reveal the fuse is a bit fiddly.
There's a similar red sleeve and in-line thermal fuse behind the fan oven as well. Both are clipped to the inside frame of the oven but easily ping out.
