Hello,
My new bath has a 38mm waste, its on the end of a flexible corrugated pipe (bit like a hoover pipe) it has about a 6 inch section that is 38mm.
A 40mm compression is too big, as is a solvent weld, or push fit. But 32mm is too small. (obviously)
Any idea's how to make this work. It'd be perfect to keep this pipe, as the bath is going to be mounted in the floor, and it'd mean it could be lifted out should we need access to anything in the future. I've got a CNC lathe at work, and thought about making something from aluminium, but surely this isn't the "normal" way. Is there something i'm not familiar with?
