Flexi seals???
1 Jan 2007
Manchester
I've been asked to fit a new toilet for a customer, but the soil pipe is lead and is moulded on to the pan outlet and looks too small for a standard pan connector.
I've been advised by the Plumb Centre that the easiest way to get round the problem is to use what they called a 'flexi seal' to bridge the gap. a coupling with 2 jubilee clips...one end goes over the lead pipe and the other end over a new piece of soil pipe then work from there to the new toilet (or so i presume)
Just wondering if anyone has used one of these :confused:
Dont want to cut out the old toilet only to find i have to replace the whole soil pipe :!:
Cheers
I've done that before. I got a 3 1/2" x 4" - 4" round the soil pipe - 3 1/2" straight on the pan con. Just remove the rubber from the pan con and tighten the jubilee flexi on to it.
Worked ok for me :)
markie said:
You will get many replies but if I was a client I would not like to see j clips, it does not look professional. ;)
I did think this myself, but it is more than likely going to be boxed in if possible and this seems to be the cheapest/easiest way of doing it
Lee-King, thanks for the reply
Quite right..I`ll just get out a couple of lbs. of grade D and the blowlamp pricker.....now where did I put that 4inch thimble and the red-lead putty ;) :LOL: :LOL:
