Imminently about to start my loft extension plumbing for the en-suite. The 110mm soil pipe will have a decent enough fall and is pretty much a straight run for 4m before it has to do a bit of jiggery pokery. Fall in this problem area is not an issue, nor are sharp bends, but it has to do 4 small deviations at relatively low angles over the course of approx 2m.
With the standard angled fittings not being appropriate, my initial thoughts were towards those variable angled fittings. But they are quite large and bulky and a couple of shallow turns are in close proximity. I’ve then seen the Magicflex pipe which seems a really good option, but is a mere 480mm long. Of course I can connect a few together, but is there any longer flexible alternative I’m missing?
Would be great if there was a 2m long version. Any ideas?
