I lay 12sqM of 600x600 porcelain tiles, on electric underfloor heating just before christmas. I used unibond flexible adhesive with the additive to mix... but got stuck when it came to grouting as all the flexible grouts in the local DIY store/builders merchants were every colour but white... so I ended up using regular white grout on the basis, should it not work... breaking it out and re-grouting wouldn't be too much hard work.
Not only has the grouting failed, but the tiles haven't stuck properly either. I used quite alot of adhesive as the heating cable/core is approx 4 to 5mm - so the bed had to be quite thick. The tiles aren't coming up... but do seem to "rock" when you walk over them.
Any ides's on how I could fix this without ripping it all up?
Thanks.
Thanks.
