Hi all again & thanks for previous help.
Briefly......Had my old boiler out and a new Vaillant Ecotec Pro 28 fitted.
Fitted in Airing cupboard upstairs, where old DHW tank was.
All lovely until this winter. I watched the (Gas Safe) people fit the boiler.
The condensate runs vertically downwards inside the house for about 2 feet.
Then changes into (I estimate) 40mm black plastic pipe.
Out through the wall, 18" vertical drop then 6 feet sideways at a good
downward angle then coupled into fallpipe. It has frozen a couple of times.
It is almost impossible to run completely inside the house without floors up etc.
I'm now of course prepared to do this. (Wife insists).I intended to use 21.5mm solvent weld pipe. 3 feet vertical, 90 degrees then under the bedroom floor, (6 feet horizontal)90 degrees, short length, 90 degrees to vertical, down through the hall cupboard / gas meter place then through the external wall terminating a couple of inches above the original drain.
A bit of a job! Then, I saw this......
http://www.plumbase.com/tprod163667/section2616/MCA-FLEXIBLE-CONDENSATE-PIPE-KIT.html
Looking at what is included, 2 of these kits joined together would make this job a hell of a lot more simple as the original joining places were all in very difficult places.
The Question......Is that flexible kit (x2 joined) any good? As I say, straight runs with right angle solvent weld connectors IS possible but very difficult.
Any suggestions / advice most welcome.(Thanks for all previous).
Ian.
Ian.
