Flexible exposed expansion/joint strip
25 Jan 2008
Wiltshire
Anyone know of a flexible expansion strip - about 3mm to 4mm width that I can use along the exposed and curved (3 metre radius) boundary between an engineered oak 20mm wood floor and an existing limestone floor (finished to same level). The limestone is already edged with a 3mm brass strip. Required expansion strip will go between the brass strip and the ends of the planks butting to it.
i think you’re going to struggle to find what you need.
would try local builders merchant for ideas though as it might get a lead.
i think only way is to use brown decorators caulk or suitable colour laminate filler. i suggest this on basis they remain flexible and can be smoothed with water/washing up liquid ie so that the adjacent materials can be kept clean from inevitable spillage whilst using a sealant gun to apply a bead to the gap.
